What Do it mean when
- Vinnie
I run rough country 2.5 lift with castor correction brought second hand but fairly new,Now do you buy castor correction bushes for a 2.5 lift or just 2" or 3" ? I'm just wondering if the right bushes have been fitted ? To cause steering not self centring and vague steering ?
Cheers vinnie
I understand that castor correction bushes are recommended for 2" lifts but 1/2 an inch is likely to not cause much of an issue.
Edit: Done the Google session for you in seconds: www.jimnybits.co.uk/shop/jimny/suspensio...-bushes/prod_49.html
- Vinnie
kirkynut wrote: So is it fitted with castor correction bushes at the moment? If so they have to be the right way up to correct it or they will make it worse. Don't ask me which was they are meant to be though. I've seen diagrams though. They are made by Super Pro, so have a Google session!
Hi kirky
Just been and checked them its freezing out there ha Yep they in the right way what else cause steering not to centre itself ?
Cheers vinnie
Tracking out?
Are you sure it's only 2.5" not 3"? Rough Country are a shock manufacturer not a spring manufacturer so what springs are on it?
It would explain why it's not self centring.
Is it that bad? I drove a 3" lift without castor correction for years and it was ok.
- Vinnie
Busta wrote: Kingpin bearing stiff/seized?
Tracking out?
Got one to replace as leaking
