What Do it mean when
  • Vinnie
11 years 11 months ago #131960 by Vinnie
What Do it mean when was created by Vinnie
What do it mean when your steering do not self centre ? I'm assuming something to do with castor correction ?
I run rough country 2.5 lift with castor correction brought second hand but fairly new,Now do you buy castor correction bushes for a 2.5 lift or just 2" or 3" ? I'm just wondering if the right bushes have been fitted ? To cause steering not self centring and vague steering ?
Cheers vinnie
11 years 11 months ago - 11 years 11 months ago #132030 by kirkynut
Replied by kirkynut on topic What Do it mean when
So is it fitted with castor correction bushes at the moment? If so they have to be the right way up to correct it or they will make it worse. Don't ask me which was they are meant to be though. I've seen diagrams though. They are made by Super Pro, so have a Google session!
I understand that castor correction bushes are recommended for 2" lifts but 1/2 an inch is likely to not cause much of an issue.
Edit: Done the Google session for you in seconds: www.jimnybits.co.uk/shop/jimny/suspensio...-bushes/prod_49.html
Last edit: 11 years 11 months ago by kirkynut.
  • Vinnie
11 years 11 months ago #132039 by Vinnie
Replied by Vinnie on topic What Do it mean when
kirkynut wrote: So is it fitted with castor correction bushes at the moment? If so they have to be the right way up to correct it or they will make it worse. Don't ask me which was they are meant to be though. I've seen diagrams though. They are made by Super Pro, so have a Google session!
Hi kirky
Just been and checked them its freezing out there ha Yep they in the right way what else cause steering not to centre itself ?
Cheers vinnie
11 years 11 months ago #132040 by Busta
Replied by Busta on topic What Do it mean when
Kingpin bearing stiff/seized?
Tracking out?
11 years 11 months ago #132044 by kirkynut
Only castor as far as I can think.
Are you sure it's only 2.5" not 3"? Rough Country are a shock manufacturer not a spring manufacturer so what springs are on it?
It would explain why it's not self centring.
Is it that bad? I drove a 3" lift without castor correction for years and it was ok.
  • Vinnie
11 years 11 months ago #132092 by Vinnie
Busta wrote: Kingpin bearing stiff/seized?
Tracking out?
Got one to replace as leaking
Time to create page: 0.105 seconds
