Steering damper.
  • jimothy
11 years 11 months ago #131846 by jimothy
Steering damper. was created by jimothy
Hi guys will a steering damper cure my jimny shake. Had my new Tyres fitted today and it's started shakeing. Wheels are well balanced. Tyres are standard size.205 70 15 Forceum EXP. it did not do this before unless you hit a bump or pothole but never carried on that bad.but now you hit about 50mph and it goes mad. It's done a bit of mileage 136,000 and is a 2007. And it's the wife's but I don't want her driving it like this so it might have to go if I can't sort it. Both side king pin bearing replaced and no play in them. I have heard fitting a damper does make a difference. Any help would be appreciated as the wife loves this little car.
Jim
  • Whaley
11 years 11 months ago #131849 by Whaley
Replied by Whaley on topic Steering damper.
Are you sure its tyre related mine shock violently after i changed panard rod bushes an left a bolt loose?
jimothy wrote: Hi guys will a steering damper cure my jimny shake. Had my new Tyres fitted today and it's started shakeing. Wheels are well balanced. Tyres are standard size.205 70 15 Forceum EXP. it did not do this before unless you hit a bump or pothole but never carried on that bad.but now you hit about 50mph and it goes mad. It's done a bit of mileage 136,000 and is a 2007. And it's the wife's but I don't want her driving it like this so it might have to go if I can't sort it. Both side king pin bearing replaced and no play in them. I have heard fitting a damper does make a difference. Any help would be appreciated as the wife loves this little car.
Jim
  • jimothy
11 years 11 months ago #131859 by jimothy
Replied by jimothy on topic Steering damper.
I will check the bushes tomorrow. But I did not have all this shaking before I had the Tyres fitted. I'm going to order a steering damper at least this way the shaking may not be as violent.
Told the wife to buy a Rav but they don't listen.
11 years 11 months ago #131861 by Halford
Replied by Halford on topic Steering damper.
just a thought but pop out and check pressures
if high as usually set by garages, the wobble will be loads worse than normal at 23 lbs front. 26 lbs rear
  • jimothy
11 years 11 months ago #131868 by jimothy
Just checked this and they are 25lb all round. I might get them to check the balancing again. And I will check the kingpins in the morning I changed these about 4 months ago. I will also pop the wheels off and make sure there on properly. I will have a little clean up behind the flanges and check no crap has gone down behind the disc. I think I will order a steering damper tomorrow as we'll.
Time to create page: 0.092 seconds
