Replacing a spring/shock
- BigTobyD
11 years 11 months ago #131837
by BigTobyD
Replacing a spring/shock was created by BigTobyD
Hi all, having successfully got out of the woods after a shattered spring through jacking up and a well placed piece of concrete I'm now trying to kid myself that I could fix it more permanently myself.
What is involved in replacing the spring that was there (on a 3" lift with an additional spacer)?
Is it just a question of jack it up to the max, slip the spring into place with no trouble at all and bob's your uncle, or do you need to compress the spring first/remove other bits to get to it (I suspect this is the case!). What tools would you need to achieve this? I have a standard tool box but little else.
Also, what is the likelihood of me needing to replace the shock given that it ran with no spring at all for a couple hundred yards through the woods and then drove home on a piece of concrete rather than a spring, is the additional compression likely to have knackered the suspension too ? (the body fell/wheel rose until tyre was against bodywork).
If I need to remove the suspension, is that also an untrained monkey job? (Not that I think I'm as good as an untrained monkey!).
Cheers gents
Cheers gents
11 years 11 months ago #131843
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Replacing a spring/shock
Bottom shock bolt out then full flex and maybe take the caliper off to relieve any tension on the brake line. It should then go in by hand. Your shock should be ok,but with the bolt out you can check it for travel,resistance etc.
Grey pick up Jimny
The following user(s) said Thank You: BigTobyD
- BigTobyD
11 years 11 months ago #131916
by BigTobyD
Replied by BigTobyD on topic Replacing a spring/shock
Right, 3" front springs on order from JimnyBits - What's the worst that can happen?
11 years 11 months ago #131988
by robs5230
standard jimny - for now
Replied by robs5230 on topic Replacing a spring/shock
it is a diy job. need wheels off both sides of the axle to get the flex . watch the brake hoses . if you're leaving the shocks on you only need to remove the lower bolts on the shocks ( both sides)
Time to create page: 0.085 seconds
