Drilling rear bottom shock mounts
07 Dec 2014 23:34 #131802 by kirkynut
I've never had a problem with my rear shock mounts but rather than have the bolts sheer off and have a problem or a bolt fall out, I thought I'd drill them and put studding through.
Has anyone done this as a preventative measure before the bolt sheers in it? If so can you get away with an HSS bit as you are not drilling through the hardened steel sheered off bolt, just the shock mount on the axle?
Will it take forever with an HSS bit?
Cheers
  • helijohn
07 Dec 2014 23:47 #131803 by helijohn
Replied by helijohn on topic Drilling rear bottom shock mounts
kirkynut wrote: Will it take forever with an HSS bit?Cheers
Probably Rob.
These days I seem to be drilling bolts out all over the place and TBH it takes forever (I use HSS bits) - rotting Pinin innit lol. I tend to sharpen the drill almost twice in a use.
What choice do you have though!! :whistle:
  • X8GGY
08 Dec 2014 07:00 - 08 Dec 2014 08:27 #131806 by X8GGY
Replied by X8GGY on topic Drilling rear bottom shock mounts
I use a 10mm bolt!
It's a headlight bolt from a 3" jimny bodylift... been on for 4 laning trips now. B)
I'm planning to get some bottom shock sleeve inserts made with a 10mm hole rather than a 12mm...
Last edit: 08 Dec 2014 08:27 by X8GGY.
  • bluejimny
08 Dec 2014 08:32 #131810 by bluejimny
Replied by bluejimny on topic Drilling rear bottom shock mounts
a good 12mm drill will go through, ive done it loads of times now
  • supergaz
08 Dec 2014 08:49 #131815 by supergaz
Replied by supergaz on topic Drilling rear bottom shock mounts
I drilled mine out and used a bolt straight through, been tested hard for a few years and all great. Remember if drilling to use cutting oil.
  • reaper
08 Dec 2014 18:08 #131860 by reaper
Replied by reaper on topic Drilling rear bottom shock mounts
Will drill no problem just do it nice and slow . Drilling fast just melts drill bits :-) Use a 12mm drill not an 1/2" and get bolts with a plain shaft ...if you dont the shocks rattle like mad one of the main reasons I used bushed relocation brackets lol
Time to create page: 0.292 seconds
