Auto Electrics help! LED light bar!
- Statey
11 years 11 months ago #131654
by Statey
Auto Electrics help! LED light bar! was created by Statey
I bought myself a LED eBay special the other week and it arrived yesterday.
I was hoping to get some advice off people on how best to wire this up.
I've already got a 4 pin 30 amp relay wired up to the roof for the spots that are there but is this going to cope??
Also (I'm no goodwith the ins and outs) operating voltage 9-32v does that mean that as car battery is around 12v I won't get a good light??
Apologies for being dumb! Here's the specs from the light
LED Power: 120W
. Operating Voltage: 9-32V DC
. Waterproof rate: IP 67
. 24pcs*5w high intensity LEDs
. Optional Color: Black
. Color Temperature: 6000K
. Material:Diecast aluminum housing
. Lens material: PC
. Mounting Bracket: Zinc Alloy
. Beam Pattern: Combo Beam
. 30000 hours above life time
. Dimensions:40 inch
LED Power: 120W
. Lens material: PC
- Yellostreak
11 years 11 months ago #131660
by Yellostreak
Replied by Yellostreak on topic Auto Electrics help! LED light bar!
calculation is watts / volts = amps
so for example:
120w divided by 12 volts = 10 amps = no worries...
This 10 amps will depend a little on how well you battery is and your alternator is chucking out but expect somewhere between 8 and 12 amps so make sure your wiring and fuses consider this..
the 9-32v is the operating voltage of the unit and you wont see any difference at 12v or 24v for example.
so for example:
11 years 11 months ago - 11 years 11 months ago #131691
by Rhinoman
Replied by Rhinoman on topic Auto Electrics help! LED light bar!
The car battery is around 12V but you would usually have the engine running so you should be at around 13.8V. 120/13.8 = 8.7A but there will also be a small current drain from the built-in drive circuitry. You may need to put a filter on the supply if you get interference from it, the cheap units aren't automotive qualified and can be noisy.
Last edit: 11 years 11 months ago by Rhinoman.
- Statey
11 years 11 months ago #131726
by Statey
Replied by Statey on topic Auto Electrics help! LED light bar!
Cheers chaps!
Think I'll have a go tomorrow, Rhinoman by interference do you mean like flickering etc??
- Yellostreak
11 years 11 months ago #131733
by Yellostreak
more like a slight hum on your radio...
11 years 11 months ago #131799
by kirkynut
Replied by kirkynut on topic Auto Electrics help! LED light bar!
Looks like your relay will be up to the job but is the wire if you tap into the live that feeds the lights you already have?
