Fuel tank
- rhys15
05 Dec 2014 21:27 #131647
by rhys15
Fuel tank was created by rhys15
Has anybody removed the fuel tank in there jimny before?
Have you got any tips to help?
Cheers
Cheers
- GuardianAngel
05 Dec 2014 21:53 #131649
by GuardianAngel
Replied by GuardianAngel on topic Fuel tank
Don't smoke
06 Dec 2014 15:35 #131690
by facade
Why remove it?
If you have a leak, it will be where the mud sits on top of the filler spout: you can fix this in situ with chemical metal if you pull the rubber spout off.
Empty the tank
Remove rear propshaft.
Remove both vent pipes, big one and small dangly one alongside the fuel lines
Remove filler spout
Find the connector for the pump/gauge unit and disconnect.
Undo the bolts and lower the tank on a jack or something until you can reach the flexible pipes.
Good luck undoing them as they are those connectors that need special pliers to remove the centre (I can't even get electrical connectors apart without breaking them)
Remove tank.
Empty the tank
Remove filler spout
Remove tank.
- mickt
06 Dec 2014 16:27 - 06 Dec 2014 16:29 #131694
by mickt
Replied by mickt on topic Fuel tank
The fuel connectors are strange. Suzuki sell a special tool for about £24 odd. It is a shaped piece of plastic that fits the shape of the pipe. You have to slide it into the coupling to unlock it and then instinct tells you to pull the coupling away from the tank connection. But no, you have to then push the coupling towards the tank and then pull it away. Be very careful not to crease the plastic pipes that run to the chassis side. Unfortunately to access the connections you have to suspend the tank midway from fully up to fully down. The pipes have not got enough length to allow you to lower the tank right down. So really it is a three handed job. Two hands to disconnect the pipes whilst your third hand is balancing the tank on the jack. Obviously it is better to do the removal with the tank empty both from a weight/balance prospective and a safety angle too. A suction pipe into the tank is the way to do it but you will have to remove the anti-theft/rollover nrv in the neck of the tank to get the pipe in. It is plastic but can be removed without damage if you are careful. I have recently done this job on both the sons vitara and the daughters jimny to tidy the back end for mot as the panels needed descaling, treating with rust stopper and repainted! You will probably find the exhaust needs tying out the way. I was replacing the back box so that made it easy for me to tie it to the chassis leg. As I say it is fiddly so you need as good access as you can especially if you are lying on your back with the car on axle stands!
Last edit: 06 Dec 2014 16:29 by mickt.
- rhys15
06 Dec 2014 18:00 #131702
by rhys15
Replied by rhys15 on topic Fuel tank
Ive got to remove it to weld the floor in the back and its right above the tank (better safe than sorry).
Ive got use of a ramp and transmission jack so that should help, what end did you remove the filler pipe, at the tank or the filler cap?
How much can you lower the tank to get to the connectors??
Thanks for the help
Thanks for the help
06 Dec 2014 18:49 #131703
by facade
If you are lucky, someone has replaced the fuel lines, and they will join to the tank plastic lines with rubber fuel line above the back axle, have a look underneath, usually if the floor is rotten the fuel & brake lines went a while before.
Time to create page: 0.086 seconds
