CB Aerial Fitting
  • Dyl
11 years 11 months ago #131517 by Dyl
CB Aerial Fitting was created by Dyl
Rather than using a mag mount I would like to attach a CB arial permanently to my Jimny.
I have ordered a mount to attach to the rear door which I will fix approximately half way up.
Question is, as I haven't tried yet, does the rear door internal panel come off ok? I had a quick look and couldn't see any screws so I guess it's clipped on. Do you simply prize it off?
Also is there a good way to get the coax through from the rear door to the main part of the Jimny?
  • Flameboi201
11 years 11 months ago #131527 by Flameboi201
Replied by Flameboi201 on topic CB Aerial Fitting
The rear door just has one screw i think where the handle is and the rest with clips . A good pull and it will come off . And if you take the rear light out you should be able to run the cable through the grommet and down the side panel .
11 years 11 months ago - 11 years 11 months ago #131529 by Halford
Replied by Halford on topic CB Aerial Fitting
see here
tape the wire to the rubber sleeve, as shown
Last edit: 11 years 11 months ago by Halford.
The following user(s) said Thank You: Dyl
Time to create page: 0.088 seconds
