Throttle position sensor?
  • Grego
11 years 11 months ago #131330 by Grego
Throttle position sensor? was created by Grego
Hi all, was driving the jim the other day when the revs seemed to drop out when changing gear almost as if the engine was being turned off for one second or so inbetween changes ,also the engine cut out for no reason when moving off in first. I've also occasionally had a strange wandering idle for a couple of months .
Anyhow, this time the engine management light came on and I managed to read it before it turned off again.
It came up with P0120 Throttle/ Pedal /position sensor Switch A Circuit.
Seems about right as to how it was driving.
Question is, what and where is it, is it serviceable or do I need a new one, and also the best place to buy from if it needs to be replaced
Tia Grego
  • jb33w
11 years 11 months ago - 11 years 11 months ago #131422 by jb33w
Replied by jb33w on topic Throttle position sensor?
bigjimny.com/media/kunena/attachments/20...dy_jimny_g13b_rh.png the part with num 13420 is the throttle position sensor
Last edit: 11 years 11 months ago by jb33w. Reason: added info
  • Grego
11 years 11 months ago #131457 by Grego
Replied by Grego on topic Throttle position sensor?
Thanks JB but I should have mentioned mine is the M13a twin cam, found the thing, a slightly different place to the G13b and a bit inaccessible (and im hoping those screws are torx as you cant see the heads), also found a section in the manual about the P0120 code so guess I will try to figure it out, although if anybody can tell me how to disconnect it without breaking anything........, the MAP sensor unplugs nice and easy but this ones a bit tougher
11 years 11 months ago #131459 by j999pre
Replied by j999pre on topic Throttle position sensor?
It's on the back of the throttle body. Held on with 2 Phillips screws. You need to take the 4 12mm bolts off and lift the throttle body off. Air pipe off first
Grey pick up Jimny
The following user(s) said Thank You: Grego
  • Grego
11 years 11 months ago #131461 by Grego
Thanks James, no torx then?....., still, doesn't sound too hard
  • Tony M16a
11 years 11 months ago #131499 by Tony M16a
Replied by Tony M16a on topic Throttle position sensor?
Agree with previous comment. Two phillips/posidrive screws. Can be tight. Recently replaced but with inlet manifold off Take care or might round off screw heads. Perhaps use a 90 degree screw driver/spanner??????
Time to create page: 0.101 seconds
