Faulty 4wd controller?
- MRB
11 years 11 months ago #131294
by MRB
Faulty 4wd controller? was created by MRB
Has anyone ever had a faulty 4wd controller - is this known to actually fail?
This is my problem and it's driving me nuts! - if anyone can offer any advice, it would be most welcome. Please note that I don't want to fit manual hubs, I just want to fix the problem so that I can sell the car in fully working condition along with it's 12 month MOT and it's swanky new soft top
Problem: My 4WD light on dash flashes after about 5 to 10 seconds.
Points to note:
1) 4WD does actually works - hubs operate just fine.
2) the light used to work fine (showing a steady 4WD on dash), but it suddenly started flashing a while back
3) The hoses near hubs have been replaced as matter of course - the system has been checked with a vacuum tester by local garage when it recently had mot - vacuum system is apparently all good.
4) I've fit a new transfer box switch
5) I've replaced the grey pressure switch near solenoids
6) I've checked all hoses around pressure switch and solenoids as a matter of course (with vacuum tube from Suzuki - the stuff they use to repair it, so it's the right stuff)
So given that the system works and its just that the car *thinks* it's not working - is it likely to be the 4WD controller? Has anyone actually ever had a faulty one of these?
What does the 4WD controller even look like?
I've done all I can and I would really appreciate any further advice. Thanks.
Points to note:
- MRB
11 years 11 months ago #131384
by MRB
Replied by MRB on topic Faulty 4wd controller?
Okay I give up - manual hubs it is then
Thanks anyway guys
Thanks anyway guys
11 years 11 months ago #131389
by kirkynut
Replied by kirkynut on topic Faulty 4wd controller?
I'm not sure what you mean by 4wd controller. There's a switch that activates the vacuum system but this works as the light flashes.
You have a vacuum leak. Find it if you have the patience or follow my guide to making your hubs fixed or pay £150 approximately for a pair of manual hubs and adaptor ring.
My advice if you are selling would be to follow my guide and if a buyer questions the light flashing explain to them that they suffer from vacuum leaks and you have solved the problem with this mod that is accepted by the Jimny world and refer them to my post if you want.
If you bung the vacuum pipes the light should not flash and a buyer would never know!
- MRB
11 years 11 months ago #131392
by MRB
Thanks for the advice kirkynut, I read your post about the hubs earlier this morning as it happens.
I'd really rather fix the problem to be honest. The reason I was asking about the controller is that there is a PDF on BigJimny that give advice on the vacuum system. It refers to a 4WD controller in that file - "The controller is hidden right up under the dashboard on the top right-hand side," and has a handy guide for checking it - but I cannot find one at all. Perhaps not all versions have one, I dunno, mine is 2000 W.
So given that I don't have a vacuum leak - as confirmed by the garage - and the system does actually work - then the 4WD controller was a last attempt to find the problem. I did have patience, but I'm losing it now, so am looking for manual hubs for a quick fix.
Thanks for taking the time to offer help anyway, but personally I really don't like the idea of locking the existing hubs in permanent 4wd.
11 years 11 months ago #131401
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Faulty 4wd controller?
It's a black box my 1999 t has one
Grey pick up Jimny
- MRB
11 years 11 months ago #131403
by MRB
Thanks for that, I'll go digging again..
Time to create page: 0.089 seconds
