Changing Differential Oil
- Dyl
01 Dec 2014 20:37 #131242
by Dyl
Changing Differential Oil was created by Dyl
I have not yet changed the differential oil on my Jimny so think it may be a good idea to do so.
As a complete novice to working on cars I just want to check the process.
It looks simple enough.
Do you just undo the bottom plug ensuring there is a drip tray below and empty it. Put the plug back in and undo the top plug to re-fill?
Then how do you ensure you get the right amount back in if this is the case?
Once I do this I will look to drop the oil on the transfer box, but one question at a time
- Butta
01 Dec 2014 20:45 #131243
by Butta
Replied by Butta on topic Changing Differential Oil
Take out the top (fill) plug first because if this is seized or rounded off and you have drained the oil you are in trouble and when filling top up until it trickles out again and it will be correct if that makes sense!
- Grego
01 Dec 2014 20:48 - 01 Dec 2014 20:49 #131244
by Grego
Replied by Grego on topic Changing Differential Oil
Undo filler first, (just in case) then drain and refill till oil overflows from filler, all on a flat level surface
Last edit: 01 Dec 2014 20:49 by Grego.
- Butta
01 Dec 2014 20:48 #131245
by Butta
Also t box and gearbox same process but less space to work so a fluid transfer pump is a good investment
- Grego
01 Dec 2014 20:53 #131246
by Grego
Definately
Butta wrote: a fluid transfer pump is a good investment
Definately
01 Dec 2014 21:03 - 01 Dec 2014 21:06 #131247
by facade
Replied by facade on topic Changing Differential Oil
You will need a 10mm square drain plug key.
A 3/8 socket bar will fit but is slightly small, and tends to round off the hole, and help expand the plug and seize it in place.
The 10mm square keys are rather like rocking horse droppings, here is one on eBay at a reasonable price
item number 181538014892
Last edit: 01 Dec 2014 21:06 by facade. Reason: Can't post a link any more :(
Time to create page: 0.106 seconds
