Clunking springs
- rhys15
30 Nov 2014 21:52 #131122
by rhys15
Clunking springs was created by rhys15
Since i have fitted a 2" jimny bits lift kit the springs are always clunking when it articulating, i have rear shock relocators.
Can this be cured by fitting spring clamps?
Can rear sock relocators be fitted to the front shocks with a little moding to give some more drop?
- supergaz
30 Nov 2014 22:02 #131127
by supergaz
Replied by supergaz on topic Clunking springs
Do you still have your rubber spring seats still in place?
- rhys15
30 Nov 2014 22:41 #131133
by rhys15
Nothing in the bottom, think there might be in the top
Replied by rhys15 on topic Clunking springs
supergaz wrote: Do you still have your rubber spring seats still in place?
- GuardianAngel
30 Nov 2014 23:00 #131138
by GuardianAngel
There should be rubber seats at the top, but the bottom of the spring just sits on a dome shaped seat on the axle.
Replied by GuardianAngel on topic Clunking springs
01 Dec 2014 09:16 - 01 Dec 2014 09:18 #131166
by kirkynut
Replied by kirkynut on topic Clunking springs
They will do this as you have no castor correction, the springs bend in an arc as a result and twist and turn as they try to get straight while under compression.
If you fit castor correction bushes it will likely stop but you will always get some noise from your suspension off road. Just look at what you are doing to it!
You don't have to do this but you will have to accept and put up with the noises!
Last edit: 01 Dec 2014 09:18 by kirkynut.
The following user(s) said Thank You: rhys15
- rhys15
01 Dec 2014 14:34 #131194
by rhys15
I should have said ive got castor correction in the front, i'll just put up with the noise
Any advise on the front shock exstenders?
Cheers
Cheers
