Clunking/knocking from Rear off side when cornering?
  • minibbb
11 years 11 months ago #131120 by minibbb
My 2005 Jim has started clunking/knocking when I corner. Coming from the rear offside wheel and most noticeable when turning left.
Any ideas what it's likely to be? Is quite loud!
  • minibbb
11 years 11 months ago #131128 by minibbb
MysticRich wrote: When was last time you changed your panhard bushes ?
I've got same problem on front and rear of mine and had it before and when I changed bushes seamed to cure it.
Never have Rich! Had it two years/ 3000 miles but it's seen a fair bit of off road use.
Is it an expensive job?
11 years 11 months ago #131129 by Rhinoman
Mine is doing the same, I can't see anything wrong with it.
The following user(s) said Thank You: minibbb
  • ml1275
11 years 11 months ago #131131 by ml1275
I had something similar on one of my old jims. Turned into be the silencer banging on the towbar. Replaced the rubber hangers and all was good.
  • minibbb
11 years 11 months ago #131159 by minibbb
ml1275 wrote: I had something similar on one of my old jims. Turned into be the silencer banging on the towbar. Replaced the rubber hangers and all was good.
Ah that's interesting- had my towbar fitted a couple of months back so worth checking out!
11 years 11 months ago - 11 years 11 months ago #131161 by kirkynut
Also check the holes in the brackets your radius arms are bolted to have not elongated so that the bolt is moving in the hole.
Buy new bolts from the Bigjimny shop first as you may have to cut the old ones off. If the bolts won't turn inside the bush, do the nuts back up and don't go any further as the bolt is rusted into the tube of the bush and the bush will likely need replacing too.
Last edit: 11 years 11 months ago by kirkynut.
Time to create page: 0.094 seconds
