2nd battery wiring advice needed
27 Nov 2014 18:50 #130767 by robs5230
i had a winch on the jimny when i first got it. i got rid but kept the 2nd battery and wiring to it ( connected to the main battery as a split charging affair.).
this summer i removed the 2nd battery and wiring. the 2nd battery was a big 80 or so amp thing on the passenger side mounted on a home brew tray.
i have noticed the jimny doesn't seem to spin over as fast since i removed it ( probably just cold weather and my imagination ) so i'm thinking of putting the winch battery back in.
so.....
would the second battery increase the starting power ?
if so what is the correct way to wire it back in as i have the leads but cant remember how it was connected.
if it wouldnt help starting i'll just get a new battery or connect up the bigger one as a single.
cheers rob
standard jimny - for now
28 Nov 2014 00:07 #130783 by Busta
A Jimny should start fine with the standard ickle baby battery. If it doesn't, either the battery is tired or you have a problem elsewhere. Testing/replacing the standard battery should be your first step.
Fitting a second, larger battery will make up for a weak battery, but it's not really fixing any problems. Without having a winch for it to run, it's just adding unnecessary weight and complexity.
28 Nov 2014 06:54 #130788 by robs5230
Busta wrote: A Jimny should start fine with the standard ickle baby battery. If it doesn't, either the battery is tired or you have a problem elsewhere. Testing/replacing the standard battery should be your first step.
yep thats why i took it off in the first place. i'll check the battery. thanks
Time to create page: 0.095 seconds
