Converting Vacuum hubs to fixed hubs
- Butta
20 Nov 2014 23:20 - 20 Nov 2014 23:21 #130207
by Butta
Replied by Butta on topic Converting Vacuum hubs to fixed hubs
Great work and I will be doing similar to mine but have one question how much steering lock is lost (or rather unusable) on high grip serfaces with locked front hubs so as not to destroy the cv joints?
Last edit: 20 Nov 2014 23:21 by Butta.
The topic has been locked.
21 Nov 2014 09:13 #130218
by kirkynut
None at all. You have a diff in the front axle.
The issue of transmission wind up which stops good steering when in 4wd on a hard and grippy surface comes from there not being a centre diff.
As you are not in 4wd the front prop is not engaged in the transfer box so if free. Thus no wind up is created.
Replied by kirkynut on topic Converting Vacuum hubs to fixed hubs
Butta wrote: Great work and I will be doing similar to mine but have one question how much steering lock is lost (or rather unusable) on high grip serfaces with locked front hubs so as not to destroy the cv joints?
21 Nov 2014 09:35 #130220
Replied by mlines on topic Converting Vacuum hubs to fixed hubs
A good write up.
Its also similar to a "field bodge" you can do when they fail off-road. Undo the hub with a Torx, pull the centre out into the locked position, drop a small nut from your parts box through the centre of the hub and jam it in behind the slider (this prevents it unlocking accidently).
Its a real bodge but I have used it to stop the hub failure ruining an off-roading day.
- Butta
21 Nov 2014 09:43 #130223
by Butta
Twice it has happened to me that my hubs have not disengaged after a period in 4wd and on both occasions the car behaved as if the front brakes were stuck on if full lock was attempted I thought this was due to the cv's as once I have got them disengaged by putting it in and out of 4wd a few times I could use full lock again
21 Nov 2014 22:43 #130305
by kirkynut
Advice given by PM and thread tidied back to original topic.
Butta wrote: Twice it has happened to me that my hubs have not disengaged after a period in 4wd and on both occasions the car behaved as if the front brakes were stuck on if full lock was attempted I thought this was due to the cv's as once I have got them disengaged by putting it in and out of 4wd a few times I could use full lock again
- GuardianAngel
28 Nov 2014 12:29 #130802
by GuardianAngel
Replied by GuardianAngel on topic Converting Vacuum hubs to fixed hubs
Good thread
I have some spare vac hubs and my locking hubs need a service as they no longer work. So I am going to attempt this today/tomorrow and test it out during the week.
Hope your recovery goes well
Time to create page: 0.555 seconds
