Key fob for Central locking
- jimothy
19 Nov 2014 18:05 #130048
by jimothy
Key fob for Central locking was created by jimothy
Is there a guide to changing the battery in the remote key fob or is it a straight forward job. I have had a little look but can't see the battery in the remote. I don't want to pull it apart if I'm likely to wreck anything.
19 Nov 2014 19:07 #130053
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Key fob for Central locking
There is a little Philips screw I think?
Grey pick up Jimny
- ZookFastback
19 Nov 2014 21:22 - 19 Nov 2014 21:50 #130090
by ZookFastback
Replied by ZookFastback on topic Key fob for Central locking
If you are talking about this kind of key fob, which locks/unlocks and activates the immobiliser, there is a small phillips screw on the back and 2 batteries inside. If, after changing the batteries, it no longer works, then the instructions are in the owners manual for re-setting the code. It only takes about 5 minutes and is fairly straight forward. I have posted the instructions a few times.
Last edit: 19 Nov 2014 21:50 by ZookFastback. Reason: Left a sentence out
- jimothy
19 Nov 2014 23:04 #130112
by jimothy
Replied by jimothy on topic Key fob for Central locking
No mine is the 2 buttons on the key. I Have just seen a link on you tube to changing the battery so I will give it a try.
Central locking is working on the buttons but seems very low range. you have to go right up to the windscreen to make it work.
- ZookFastback
20 Nov 2014 01:17 #130120
by ZookFastback
A hint to improve range... raise the remote device to your head. The head has water in it (Some more than others
) and acts as an amplifier/range extender :evil:
:woohoo:
jimothy wrote: No mine is the 2 buttons on the key. I Have just seen a link on you tube to changing the battery so I will give it a try.
:woohoo:
20 Nov 2014 06:39 #130121
by facade
Replied by facade on topic Key fob for Central locking
I didn't believe this either, but it is true :ohmy:
I can work my locking from the other side of the carpark at work if I hold the fob by my ear, simply holding it up in the air above my head doesn't work.
Time to create page: 0.118 seconds
