Malfunction Indicator Light
- Hall
12 years 2 days ago #129802
by Hall
Malfunction Indicator Light was created by Hall
Ok folks, got an '06 jimny, coming home tonight the orange engine symbol (malfunction indicator light) came on. Book says its the computer controlled emission control system and light coming on means the emission control system needs servicing and if it comes on when engine running there's a problem with it and take it to a Suzuki dealer.
Is this a cheap fix or do I need to sell a kidney?
Is it something easily fixable by me (not much of a mechanic) or does a garage need to do it?
Cheers in advance for any help,
Graham
Graham
12 years 2 days ago #129810
by robs5230
standard jimny - for now
Replied by robs5230 on topic Malfunction Indicator Light
need to get the fault code read . not necessarily at a main dealer. could be cat or lambda sensor
12 years 1 day ago #129830
by kirkynut
Replied by kirkynut on topic Malfunction Indicator Light
If the car is running fine there's no rush to fix it. As has been said, you need a code reader ideally.
If it's a twin cam engine, found in hard tops of that age, you need an OBD2 code reader, which are plentiful on the Internet, I can help you then. If it's a single cam others on here will be able to help you.
I'm not sure if or when the single cam went to obd 2 or if the soft tops ever got twin cams.
If it's a single cam soft top on obd 1, there's an obd 1 reader sold in the BigJimny shop.
I expect it to just be a dodgy lambda sensor or cat not working efficiently enough to filter out the nasties.
- Reloaded
12 years 1 day ago #129841
by Reloaded
Replied by Reloaded on topic Malfunction Indicator Light
Single cam engines from 51 plate on are OBDII compliant. I just use a cheap Bluetooth OBDII device bought from eBay and the Torque Pro app on my phone - works a treat.
- Hall
12 years 1 day ago #129850
by Hall
Replied by Hall on topic Malfunction Indicator Light
Thanks for the info folks. Couldn't get any local garage to look at it today so bit the bullet and took it to kwikfit. They couldn't get a fault code out of their machine but said it was the throttle position sensor! Light is now off and I've driven about 50 miles and all seems well. Think I'll get one of the code readers myself though to be on the safe side!
- Tony M16a
11 years 11 months ago #130546
by Tony M16a
Replied by Tony M16a on topic Malfunction Indicator Light
I have an '01 twin cam. The engine management light has a habit of coming on fairly regularly particularly if having been driven for some time on low engine revs.
Not a 'by the book cure' but....... Have found that if the engine is revved hard for a period to warm up the cat and clear any sooting up of the cat the light can then be reset to off by disconnecting the battery for at least one minute. In my experience the light will then stay out!!!!
OK Not hi tech but has worked for me.............
Time to create page: 0.096 seconds
