Clutch adjustment
- rexthecat
Looked up how to adjust it when I got back.
Is it just the plastic adjuster on the gear box??
Ha looks so easy, propper stress trying to drive it through london! Anyone know why the cable would get tight, I thought they get loose, more play as the clutch wears?
Atleast looks like an easy fix though unless it's seized
Cheers
- Vinnie
rexthecat wrote: Driving home from some really fun greenlaning today my clutch started to slip, was slipping a bit early on but got really bad just a couple of miles from home, just about made it. It's not the first time it's happened, got it adjusted last time, cable was too tight.
Cheers
Sorry cant help on adjustment But good meeting you guys and a good day was had
Vinnie
There is a thread but it maybe difficult to turn if old.
I put a new cable on mine and it was so much nicer.
- Johnniehec
- Thank you received: 56
No it gets tighter as clutch wears so you need to loosen it.
- rexthecat
- rexthecat
