removing the prop between gbox and tbox
- Thank you received: 77
16 Nov 2014 13:29 #129696
by robs5230
standard jimny - for now
removing the prop between gbox and tbox was created by robs5230
i will be replacing the small prop between the gearbox and transfer box this week to try and correct a problem. can anyone let me know the correct way to do this ? anything to watch out for etc ? thanks
16 Nov 2014 13:38 #129699
by kirkynut
Replied by kirkynut on topic removing the prop between gbox and tbox
It's been a while since I did this but essentially you undo the prop at the transfer box end. Then slide it out of the gearbox but keep the bit that slides out straight so as not to damage the oil seal it runs in.
The following user(s) said Thank You: robs5230
16 Nov 2014 16:14 #129719
by robs5230
Replied by robs5230 on topic removing the prop between gbox and tbox
thanks for that. i do have a new oil seal to throw in that i ordered a while ago but never got round to doing.
would i need to put on some kind of reference mark to make sure it goes back in the same place or is this unneccessary ?
- mickt
16 Nov 2014 17:00 #129728
by mickt
Replied by mickt on topic removing the prop between gbox and tbox
It would not hurt to mark it just in case you do get a vibration, at least that can be eliminated!
Time to create page: 0.086 seconds
