Steering groan - damper?
  • Caulkheader
16 Nov 2014 12:08 #129685 by Caulkheader
Steering groan - damper? was created by Caulkheader
Having had a damper on my previous Jimny I fitted the Pro Comp kit to my new 2014 one.
Its been on for a week or so now and it has made a positive difference to the drive. However I now have a groan from the steering whenever I give it any right hand lock. The noise is only there as I move the wheel.
I suspect its hydraulic fluid under pressure. I have removed the damper and the noise has gone.
Any thoughts from the forum as to wether this is the damper or rack at fault or is this to be expected with a damper (didn't happen on my old Jimny). I would be surprised if it were the rack as the car has only done 1200 miles.
16 Nov 2014 14:00 #129701 by kirkynut
Replied by kirkynut on topic Steering groan - damper?
I think I'm right in thinking your Jimny is nearly new. At which point I expect it to be something to do with the steering damper and would put a bit of rubber grease on the bushes if rubber and some other grease on them if nylon, which ought to solve the noise. If not, I wouldn't worry about it unless it's driving you mad!
A squirt of WD40 on the suspected bushes will stop it temporarily for diagnosis purposes first.
The following user(s) said Thank You: Caulkheader
  • Caulkheader
18 Nov 2014 19:19 #129944 by Caulkheader
Replied by Caulkheader on topic Steering groan - damper?
Thanks, yes it is new, my second one.
The supplier is going to exchange the damper for a new unit. I'll fit it and see what happens.
Cheers for the response
Time to create page: 0.079 seconds
