Winch Cable Diameter?
  • Jimny-Dave
12 years 5 days ago - 12 years 5 days ago #129425 by Jimny-Dave
Winch Cable Diameter? was created by Jimny-Dave
Made my rear winch tray yesterday, and it's gone off for powdercoating...
Now shopping for cable to run from the Odyssey PC1200 winch battery under the bonnet down the chassis and to the winch under the back bumper...
Ok, now to the point...
They do various sizes of cable -
25mm2 / 9.8mm OD / 170 Amp Rating
40mm2 / 11.8mm OD / 240 Amp Rating
60mm2 / 14.5mm OD / 415 Amp Rating
I've measured the standard cable that is already on the (T-Max 9,500lb) winch and that is 10mm OD (the measurements above are also including the sheath), given the run from the battery to the winch should I use thicker cable? Will there be more power draw, or is the length of the cable insignificant?...
Dave
Last edit: 12 years 5 days ago by Jimny-Dave.
  • supergaz
12 years 5 days ago - 12 years 5 days ago #129438 by supergaz
Replied by supergaz on topic Winch Cable Diameter?
I'd use the 60mm2 for running that distance.
Also fit an inline mega fuse.
Welding cable is sometimes a cheaper option.
Last edit: 12 years 5 days ago by supergaz.
  • TomDK
12 years 5 days ago - 12 years 5 days ago #129440 by TomDK
Replied by TomDK on topic Winch Cable Diameter?
Jimny-Dave wrote: Made my rear winch tray yesterday, and it's gone off for powdercoating...
Dave
You could probably do with a 35mm2 if the winch was near the battery. But now the winch is at the other end of the car I'd go for 50mm2 at least. I use 70 mm2 to feed my 2 bowmotor 1's. Battery in the back, winch at the front. I really should consider getting 95mm2 cable :)
Nobody uses fuses for winches. Waste of money. Get a good quality battery isolator instead.
Last edit: 12 years 5 days ago by TomDK.
  • Jimny-Dave
12 years 5 days ago #129457 by Jimny-Dave
Replied by Jimny-Dave on topic Winch Cable Diameter?
Yours are over-volted from what I read though Tom?
  • TomDK
12 years 4 days ago - 12 years 4 days ago #129481 by TomDK
Jimny-Dave wrote: Yours are over-volted from what I read though Tom?
Correct. But amperage it the same for 12 volts and 24 volts :)
Red Winches made this very informative chart :)
I know it's for 2 bowmotor 2's, but still :)
scontent-a-ams.xx.fbcdn.net/hphotos-xap1...e1e197a9&oe=54E6CA5E
As you can see, there's only a 10% increase in AMP going from 12 to 24 volts :)
Last edit: 12 years 4 days ago by TomDK.
  • Jimny-Dave
12 years 3 days ago #129614 by Jimny-Dave
Hmmm... looking again...
25mm2 is £5.11 a metre, plus Vat
40mm2 is £8.25
60mm2 is £12.43
Do you think 40mm2 would be sufficient for the odd bit of winching I'm likely to do?... considering normal winch cable is 25mm2?
Time to create page: 0.095 seconds
