no drive to front wheels
  • Gjmcleod
09 Nov 2014 14:41 #129009 by Gjmcleod
no drive to front wheels was created by Gjmcleod
Hi guys , I have been out off roading this morning , 4WD was working fine , , then all of a sudden , no drive to the front wheels , no bangs or clunk s prior to the loss of drive .
- the front prop is spinning , as the rear wheels are spinning , but no drive
- anybody able to advise on the first things to check ?
- the car is trailer , not sure what hubs are on it , its just normally constant 4 wheel drive
Any advice would be much appreciated ?
Cheers
09 Nov 2014 15:46 #129019 by auchenblae
Replied by auchenblae on topic no drive to front wheels
Sounds like a freewheeling hub has failed are you getting a flashing light on the speedo
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
  • Gjmcleod
09 Nov 2014 16:27 #129020 by Gjmcleod
Replied by Gjmcleod on topic no drive to front wheels
Hi , my light always flashes on the dash , it's only used off road , so the hubs are just locked in 4 wd , i just thought it was strange that both wheels have stopped driving , if one hub went , would both wheels not have drive ?
Thanks
  • supergaz
09 Nov 2014 16:57 #129026 by supergaz
Replied by supergaz on topic no drive to front wheels
If 1 hub fails you loose all drive to the front. Check these first before pulling the shafts out, then after those it could be a diff.
09 Nov 2014 17:00 #129028 by facade
Replied by facade on topic no drive to front wheels
All the drive goes to the side that is free to turn because of the differential.
Most likely reason is a CV joint has failed, although you might be lucky if you have vacuum hubs that are just fitted in the locked position and find that one has flipped back to free.
You have to dismantle the swivel housing to get the driveshaft out, sometimes you can tell which has failed because that wheel is easier to turn.
Start by checking the hubs, they have to come off to get the driveshafts out anyway.
  • idiotmobil
09 Nov 2014 17:03 #129029 by idiotmobil
Replied by idiotmobil on topic no drive to front wheels
I second the cv joint you need to stock pile some lol
Time to create page: 0.106 seconds
