Front wheel bearing question
- mc_nebula
07 Nov 2014 23:05 #128856
by mc_nebula
Front wheel bearing question was created by mc_nebula
If I'm going to do a wheel bearing, and have a spare front half shaft, could I press the bearing onto the spare bare half shaft before I dismantle the car, or do I need other parts to be held captive, like the rear, where the rear bearing holds the drum backing plate captive?
cheers
Ali.
cheers
Ali.
07 Nov 2014 23:07 #128857
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front wheel bearing question
The front wheel bearing sits in the drive hub. You can leave the shaft and the main hub body in situ
Grey pick up Jimny
The following user(s) said Thank You: mc_nebula
- mc_nebula
07 Nov 2014 23:14 #128861
by mc_nebula
Replied by mc_nebula on topic Front wheel bearing question
ahhh, so the bearing is pressed into the hub, not onto the shaft? I think I recall reading that now. I also think that now my mind has been jogged, that I've heard of people removing the old one with a big hammer, and inserting the new one with the aid of a freezer and oven?
I've got a severe oil leak on my passenger side, and it's probably the seal, but a garage told me it could be the bearing too...
07 Nov 2014 23:32 #128862
by j999pre
Grey pick up Jimny
Probably king pin bearings causing the inner axle oil seal to fail(the little one). If you have play in the wheel when jacked up at 12 and 6 o'clock but not 3 and 9 it will be kingpins. If the play is all round but disappears when someone puts their foot on the brake pedal it will be wheel bearing.
Grey pick up Jimny
- mc_nebula
07 Nov 2014 23:57 #128863
by mc_nebula
the kingpins on that side are sound, and there is no play laterally either. the other sides kingpins are wrecked and I'm going to do them tomorrow. no oil leak though. When you say inner seal, you mean the one push fitted into the axle?
The rubber ring around the sphere isn't really an oil seal, is it? more of a dust cover?
08 Nov 2014 08:20 - 08 Nov 2014 08:23 #128867
by kirkynut
Replied by kirkynut on topic Front wheel bearing question
If there's a leak there's a reason for it and I doubt it is just the oil seal alone, especially as it is normally rear wheel drive, so the wear on the seal will be minimal.
The chances are that the kingpin bearings are shot in both sides, not just one. You've got to strip it down to them to change the oil seal, so you may as well change the bearings.
Last edit: 08 Nov 2014 08:23 by kirkynut.
Time to create page: 0.105 seconds
