Front towbar and rear worklights
  • woody woodpecker
07 Nov 2014 11:58 #128802 by woody woodpecker
Front towbar and rear worklights was created by woody woodpecker
Hi,
I'm new to forum and would like to know if anybody has info on fitting a front towbar for shunting trailers and also a wiring diagram for rear working lights on a separate toggle switch.
thanks,
Chris.
  • 410shotgun
07 Nov 2014 19:06 #128825 by 410shotgun
Replied by 410shotgun on topic Front towbar and rear worklights
you could make 1 up it would not be a hard job
if you take the centre black part out of the bumper
you can get to the front cross member
I have done this on my other 4x4s over the years land rover / Nissan patrol / hilux / Nissan pick up
but not the old jimny
08 Dec 2014 12:46 #131833 by Busta
I wired up my reversing lights to a toggle switch on the dash. I bridged the wires to the reverse switch on the gearbox, then traced the wire back to the fuse box and put a rocker switch in one of the blanks to the right of the steering wheel.
If you need more light than that, I'm sure you could run a decent LED floodlight off the same reversing light wiring.
For the front towbar, take off the front bumper and you'll soon see what you've got to play with. The Jimny-bits front recovery point/winch tray would be a good starting point to fix a hitch to.
www.jimnybits.co.uk/shop/jimny/accessori...plate/prod_1402.html
Time to create page: 0.079 seconds
