Larger Sized Tyres
- BigAndy
12 years 1 week ago #128775
by BigAndy
Larger Sized Tyres was created by BigAndy
In the coming weeks I'll be swapping my 205 70 15s for 215 75 15 A/Ts for winter. I know you can get apps and websites that work out the difference but what are people real life findings when increasing tyre size? This isn't a huge increase, what do others with the same size larger tyres think? Speed-wise and MPG?
Cheers.
Cheers.
12 years 1 week ago - 12 years 1 week ago #128779
by Busta
Replied by Busta on topic Larger Sized Tyres
I run 215/75 15s, which are 6% bigger than standard. I noticed that it isn't quite as 'nippy' (I hate that word but can't think of a better one) as it was on the standard tyres and that maintaining higher speeds seem a bit harder work but it's a fine compromise. The combination of the speedo reading lower and the gearing being longer makes it seem a bit worse than it actually is.
Fuel economy dropped about 10% on paper but when you factor in the odometer is under-reading by 6% it's only a 4% difference really. That's with M/Ts so A/Ts will be better.
Last edit: 12 years 1 week ago by Busta.
12 years 1 week ago #128788
by robs5230
standard jimny - for now
Replied by robs5230 on topic Larger Sized Tyres
larger tyre will mean you are up and down the gearbox and have to make the engine work harder. both will have an effect on mpg. 215's are about the biggest tyre you can fit without a lift. they will fill the arches though and you will have less possible articulation if going off road. an a/t will also have a greater rolling resistance than a standard road tyre again affecting mpg.
on a like for like pattern tyre the 215's are about 36mm greater in diameter than the 205's. thats only 18mm increased clearance. you have to work out whether the increase in clearance or the "looks" are worth the trade off.
i run 195 80 15 which are 25mm greater in diameter. thats 1/2 inch clearance and doesn't seem to affect anything in an a/t tyre. i get 35mpg.
- steffan
12 years 1 week ago #128790
by steffan
Replied by steffan on topic Larger Sized Tyres
Haha 35mpg in a jimny what you towing it with lol
- Whaley
12 years 1 week ago - 12 years 1 week ago #128796
by Whaley
Replied by Whaley on topic Larger Sized Tyres
Im running 195 80 15 and im still getting 30 mpg and its all town driving they are hankook dynapro AT tyres and as mentioned above you gain about 1/2 " ground clearance.
Last edit: 12 years 1 week ago by Whaley.
12 years 1 week ago #128797
by Busta
215s won't limit articulation
Mine are fine, even with the ARB removed.
robs5230 wrote: 215's are about the biggest tyre you can fit without a lift. they will fill the arches though and you will have less possible articulation if going off road.
Time to create page: 0.090 seconds
