help needed quick....
  • davert85
12 years 1 week ago #128714 by davert85
help needed quick.... was created by davert85
Got the jimny jacked up and fitting new shocks and springs, front was done no issues but the rear.... Not so.
The bolt is stuck in the busing sleeve and WILL NOT come put. Its been undone but its stuck in the sleeve so cant pull the old shock off. This wouldn't be an issue if I wasn't doing it in my mates driveway on a time limit.
Any suggestions please let me know. Iv blow torched it, crow bar the lot. Shall I hacksaw the end off....?
Stuck!
  • jimothy
12 years 1 week ago #128742 by jimothy
Replied by jimothy on topic help needed quick....
If the bolt is loose Just cut the top of the shocker mount through the ring bit that goes around the rubber. Remove the dead shocker out the way.and cut the rubber bit off then your left with the sleeve around the bolt give the bolt a cut right at the head end on the inside of the body mount. so it's left with just the inside bit and the bit in the thread. One more cut right in the middle gives you enough room to wind the rest out of the thread out and remove it. Poxy job but it happens.hence Martin sells the bolts in the shop
  • Vinnie
12 years 1 week ago #128749 by Vinnie
Replied by Vinnie on topic help needed quick....
davert85 wrote: Got the jimny jacked up and fitting new shocks and springs, front was done no issues but the rear.... Not so.
Stuck!
Mine was like that on rear. It unthreaded out of bolt but wouldn't come out of sleeve,I just cut the bolt through and removed head the shock then had enough movement to wiggle out
Vinnie
  • davert85
12 years 1 week ago #128777 by davert85
Replied by davert85 on topic help needed quick....
Stuck!
Vinnie
Cheers for the replies guys. Two hours later and She's done!!! The other side took about 30 minutes to do the whole lot!!
  • mc_nebula
12 years 1 week ago #128864 by mc_nebula
Replied by mc_nebula on topic help needed quick....
my mate had a bolt stick in a radius arm. it wouldn't move for anything we tried. Heat, levering, hitting, trying force with a G cramp...
He was able to borrow a snap on impact gun and that got it out!
  • rs200boy
12 years 1 week ago #128952 by rs200boy
Replied by rs200boy on topic help needed quick....
Same problem with mine drivers rear I melted through with the works burning gear
