Suspect Faulty Front ABS Brake Sensor
- overthetop
05 Nov 2014 07:58 - 05 Nov 2014 08:04 #128540
by overthetop
Suspect Faulty Front ABS Brake Sensor was created by overthetop
2004 Suzuki Jimny 1.3 petrol
I suspect I have a faulty front near side ABS sensor.
It appears not to have a disconnecting plug /socket at the hub; connection is probably done at the ABS pump control unit?
Is the sensor likely to be a 2 wire or a 4 wire device?
What values of electrical resistance readings should I be looking for if I find the plug/socket?
Can the wires be rejoined if found damaged or are the wires themselves something special?
The sensor looks pretty tight in the hub; bound to damage it if attempt to remove it for closer inspection.
I was told by one mechanical they cost over £150 each at the dealership.
Can anyone suggest source of a replacement abs sensor at a sensible price?
Thanks in advance for any advice given.
overthetop
overthetop
Last edit: 05 Nov 2014 08:04 by overthetop. Reason: spelling error
06 Nov 2014 19:34 #128736
by Rhinoman
Replied by Rhinoman on topic Suspect Faulty Front ABS Brake Sensor
The sensor is a two wire device, I don't know the resistance but quite often they check out OK on a resistance test even when they are faulty. The wires are nothing special. Its probably seized in the hole and the bolt may also be seized, when I tried to remove one of mine the head of the bolt sheared off. I would try a local motor factors or eBay for a replacement sensor.
Time to create page: 0.073 seconds
