steering creak
- apache
12 years 2 weeks ago #128448
by apache
steering creak was created by apache
Hi I have a creaking noise from my steering any ideas? comes on as turn right but all joints appear ok and no movement from steering box sounds like dry plastic rubbing (sorry hard to describe) have just replaced springs and shocks and everything looks ok on underside noise was there prior to spring change
12 years 2 weeks ago #128450
by kirkynut
Replied by kirkynut on topic steering creak
Crickey, it could be so many things!
I would have a look at all of the suspension bushes if the ball joints are known to be good. I would start with the radius arm bushes.
Have you checked the UJ on the steering column shaft that is in the engine bay going down to the steering box?
I wouldn't get too hung up on it.
I suppose the best way to check each bush is to have an assistant do the steering whilst you spray each one with WD40 and see if the noise goes when the WD40 is on it.
- apache
12 years 2 weeks ago #128524
by apache
Replied by apache on topic steering creak
do you know if there are any nylon bushes in column have checked UJ and bushes nothing, only hear it at very low speed but sounds as if inside cabin ! annoying if nothing else.
12 years 2 weeks ago #128550
by kirkynut
Noises get transmitted through the car as metal is good at it. So it becomes hard to find.
Could it be the plastic shrouding around the steering wheel and ignition switch area?
- apache
12 years 2 weeks ago #128551
by apache
will continue the search cheers
Time to create page: 0.089 seconds
