Drumming/rumbling noise from underneath ?
- Johntom
My 02 reg Jimny has a drumming/rumbling/vibration noise from underneath when accelerating at lower revs (most obvious in 3rd and 4th, a bit like its labouring) it also does it on the overrun but a slight touch of the throttle makes it go away. The car feels to vibrate through the floor as though something's out of balance - the noise goes when the clutch is pressed down, so it's gearbox onwards issue. I have changed the fluids in the diffs, the gearbox and transfer box. I have driven the car with the rear prop disconnected and again without the front and the noise is still there. At the weekend I replaced the transfer box mounts as they were soft but still the noise remains ? Thinking either the gearbox, transfer box or the prop from the gearbox? Any ideas how I find the problem?
- Vinnie
Johntom wrote: Hi
Mine makes a noise as you describe and goes when clutch pressed down this is normally the thrust bearing on clutch but mine isn't noticeable when driving so maybe yours is about to explode
Vinnie
Grey pick up Jimny
- Johntom
it doesn't sound like the clutch bearing and the clutch was replaced very recently, there is no clutch noise when the car is stationary and the pedal is pressed. I have removed front and rear props tonight and revved the engine with the car in gear (but obviously not moving) and the noise isn't there. The 'V' shaped rubber to metal gearbox mount at the back of the box has started to break up though ? are these available anywhere other than Suzuki?
Grey pick up Jimny
- Flameboi201
