How to fit Ignis sport recaro into a Jimny
- blitz9994
30 Oct 2014 23:24 #127993
by blitz9994
How to fit Ignis sport recaro into a Jimny was created by blitz9994
Hope this helps here is a quick write up of the steps i took to fit the Ignis sport recaro into my jimny
Start of by sourcing a set of ignis sport seats I picked up a mint set of fronts for £80
Unbolt the jimny seats 2 14mm bolts at the front then slide seats forward to get at the rear 2 14mm bolts they may be covered with a plastic trim that you pries up, now with both sets of seats side by side the fun starts.
Start by unscrewing the plastic side trims using a posy drive screwdriver the lever plastic slides forward of a clip and it hides a screw
Next unbolt the 4 12mm seat base bolts
Next unbolt the 4 14mm back piece bolts
now unclip the fabric from the back of the upright section
This reveals the bar that needs lengthening
You are now left the bare subframe repeat this on the ignis seats
Now you will need to lengthen the jimny bar that operates the upright seat adjuster cut the bar in half and i used a section of threaded bar to slide inside the tube you need to lengthen the bar 1"
Now the bar has been extended fit the back upright back onto the jimny subframe the bar locates on a center piece and a notch in the mechanism
Then refit the seat base with the 4 12mm bolts and refit the plastic side trims
Have a stand back with a fag and a cuppa admire your work as your almost there
Now refit them into the jimny with the 4 14mm bolts tighten up and take a seat lovely and comfy
- NineCherries
31 Oct 2014 00:13 - 31 Oct 2014 00:15 #128001
by NineCherries
Replied by NineCherries on topic How to fit Ignis sport recaro into a Jimny
I'll need to find an Ingnis to get the seats from and a Jimny to put them in now, but when I doo at least I know how to fit the seats lol. Good wee write up, I've always admired those seats, old school cool withe the mesh head rests
Last edit: 31 Oct 2014 00:15 by NineCherries.
- blitz9994
31 Oct 2014 00:29 #128002
by blitz9994
Replied by blitz9994 on topic How to fit Ignis sport recaro into a Jimny
They are awesome and comfy and my main concern over bucket seats is the need to still be able to put the kids in the back
- minibbb
31 Oct 2014 04:46 #128003
by minibbb
Replied by minibbb on topic Re:How to fit Ignis sport recaro into a Jimny
Hero!! What an awesome write up cheers mate! Mine arrive today so can get cracking!
- minibbb
31 Oct 2014 09:05 #128015
by minibbb
The only thing i don't understand is that having to lengthen the bar by one inch surely would suggest the base of the subframe is now an inch wider? Does it still bolt in the original holes in the floor ok?
- supergaz
31 Oct 2014 09:27 - 31 Oct 2014 09:29 #128018
by supergaz
Replied by supergaz on topic Re:How to fit Ignis sport recaro into a Jimny
The seats I think are about an inch wider. I didn't have the originals to compare as I had scooby seats before. Nothing fits the Jimny better or easier than the ignis recaro's
It still all bolts up fine into the original holes.
Last edit: 31 Oct 2014 09:29 by supergaz.
Time to create page: 0.195 seconds
