Trailing arms/Radius arms
  • BigTobyD
12 years 3 weeks ago #127730 by BigTobyD
Trailing arms/Radius arms was created by BigTobyD
Hi all, beginner with no mechanical knowledge here as will become clear shortly!
I've been told I need replacement bushes for the trailing arms on my Jimny. Looking around I see lots of mention of radius arms, are these the same thing as trailing arms? Looks like I need 2 x Radius arms to axle bushes and 1 x Radius arms to chassis bushes for each arm, is this right? I'm losing the will to live working it out for myself and these things aren't cheap! I have castor corrected arms so shouldn't need castor corrected bushes.
Many thanks for any help you can give!
Toby
12 years 3 weeks ago #127732 by j999pre
Replied by j999pre on topic Trailing arms/Radius arms
Trailing arms and radius arms are the same and yes the bush quantity you mention is correct
Various options for replacement ie original, poly bush or super pro
Grey pick up Jimny
The following user(s) said Thank You: BigTobyD
  • BigTobyD
12 years 3 weeks ago #127739 by BigTobyD
Replied by BigTobyD on topic Trailing arms/Radius arms
Thank you, makes sense now then! What's the best bush for hard off-roading, more pay and play than green laning..
  • darthloachie
12 years 3 weeks ago #127746 by darthloachie
Replied by darthloachie on topic Trailing arms/Radius arms
BigTobyD wrote: Thank you, makes sense now then! What's the best bush for hard off-roading, more pay and play than green laning..
Superpro are the best and you still get as much articulation as rubber bushes
  • BigTobyD
12 years 3 weeks ago #127755 by BigTobyD
Thanks gents, the fog has now lifted!
  • Sprocket
12 years 2 weeks ago #127958 by Sprocket
Replied by Sprocket on topic Trailing arms/Radius arms
I've got SuperPro on mine and there fine on road and have been perfect for the limited offroading I've done.
You need a hydraulic press to get the old ones.
