4WD light flashing advice
  • MRB
26 Oct 2014 15:23 #127567 by MRB
4WD light flashing advice was created by MRB
Hi,
I've seen lots of posts about this and I have the information on "checking the vacuum system", but I'm a little confused and hope that someone with some experience of this might be able to help.
My jimny is for sale (listed under For Sale And Wanted section) and I would like to be able to solve this for the the new owner if possible.
When 4WD is selected, The 4WD light on the dash flashes about 5 or 10 seconds later - it suddenly started doing this a while back, after a visit to the garage for something else, but I never followed it through. The key thing is that the 4WD DOES WORK because the front hubs are engaged when 4WD is selected. I know this because if you jack up the front wheels at a time, they go from freewheeling, to locked.
I'm thinking that if the hubs are engaging every time I test it, the vacuum system must surely be okay???
It must be just that the car THINKS its not in 4WD - when in fact it IS.
The PDF "checking the vacuum system" - which I was kindly pointed to from the forum last time I asked about this - suggests that itt may be the "pressure switch". Is this the same thing as the "4WD switch on transfer box" or are they different things?
Thanks for any help as usual.
Mark
  • MRB
27 Oct 2014 17:35 #127641 by MRB
Replied by MRB on topic 4WD light flashing advice
I've ordered a transfer box switch - all I can do is try it I guess. I'll update the post when I've exchanged it, in case it helps anyone else.
Thanks anyway.
28 Oct 2014 11:28 #127703 by facade
Replied by facade on topic 4WD light flashing advice
When you engage 4wd at tickover, can you hear the hubs clack-clack, and then on disengage they clunk-clunk?
If so, likely is the pressure switch connected to the nest of pipes under the battery.
If not, the most likely reason is the small rubber hose from the spigot on the inlet manifold to the nest of pipes is missing, and the hubs are permanently engaged, the reason the fronts turn when in 2wd is because the transfer is freewheeling.
  • MRB
02 Nov 2014 19:03 #128243 by MRB
Sorry, I've just seen this reply - appreciate it thanks!
Yes, the front wheels properly engage/disengage no problem, it's just the light on the dash that flashes.
I changed the switch on the transfer box, but that's not changed anything. I found the pressure switch today after removing the air filter and battery. Connections were pretty dirty, but cleaned them and again, nothing changed (4WD still flashing). Also cleaned the small "air filter" that is connected to pressure switch, but this was okay too. All hoses that I can see/check *appear* to be in good condition, so I'm wondering if the pressure switch itself is faulty?
BTW - the small rubber pipe you mentioned is just fine (removed and checked).
Any ideas on how to test/check the pressure switch is working?
Thanks,
Mark
02 Nov 2014 19:25 #128248 by j999pre
Replied by j999pre on topic 4WD light flashing advice
I have a pressure switch you can try If you want to pop over to Todmorden
Grey pick up Jimny
The following user(s) said Thank You: MRB
  • MRB
02 Nov 2014 19:55 #128257 by MRB
That's a really generous and helpful offer thank you so much. I will try to find out how to test one first, but if I get stuck with finding out how to do that I will definitely take you up on that offer - or happily buy it from you (assuming it's for sale?).
Thank you :)
Mark
Time to create page: 0.096 seconds
