Jimny transfer guard
- cal213
12 years 3 weeks ago #127391
by cal213
Jimny transfer guard was created by cal213
Does anyone run a transfer guard with a rockwatt bucket? Curious to see what people are tunning and if they have broken mounts or rubbers without using a bashplate under the rockwatt
12 years 3 weeks ago #127550
by kirkynut
Replied by kirkynut on topic Jimny transfer guard
The Rockbucket is a bomb proof guard!
So I am not sure what you're looking at.
- RichiesJimny
12 years 3 weeks ago #127553
by RichiesJimny
Replied by RichiesJimny on topic Jimny transfer guard
I used an ora transfer box gaurd with my Rockwatt mount but only because I'd bought the guard before I switched to a 410 box with a Rockwatt mount, both fitted together without any issues the ora gaurd does have a smooth bottom so maybe helps to slide over rocks etc, if you've got a Rockwatt bucket you don't need the transfer guard but if you've already got one you might as well use it.
- cal213
12 years 3 weeks ago #127597
by cal213
Replied by cal213 on topic Jimny transfer guard
Awesome, was basically just wanting to know the strength of the Rockbucket, i do have a guard there, main concern was if i did park the car on a rock, would it push up fairly firmly causing the rubber mounts to stretch and break?
I guess anything is possible, but even with an ora guard i would be pushing on the main transfer arms to the chassis.
Time to create page: 0.076 seconds
