wheel spacers...
- davert85
12 years 3 weeks ago #127361
by davert85
wheel spacers... was created by davert85
I'm looking at getting some of there purely so I don't feel like I'm going to fall over in my little roller skate.
Iv seen a number of people with 32mm which is what I was going to go for, but iv also seen some interesting things on other forums about wheel bearings going after 1000 miles or so, people doing 65 then suddenly serving to the left/right when the bearings go etc etc and other horror stories. What's your opinions on spacers? How big have you/would you go? Is 20mm better than 32mm? Are the stories of firery balls of death real? Is it worth it?
Are off set rims better? Shall I......shan't I......????
Thanks ik adavnce.
David.
Thanks ik adavnce.
David.
- jonesyba420
12 years 3 weeks ago #127379
by jonesyba420
Replied by jonesyba420 on topic wheel spacers...
When you say you feel like your gonna fall over is this on road or offroad?
Imo you will lose the back end and spin out way before you fall over on road from hard cornering or evasive driving.
Offset wheels are better as your not adding a component but they will put the same strain on wheels bearing etc.
12 years 3 weeks ago #127601
by robs5230
standard jimny - for now
Replied by robs5230 on topic wheel spacers...
I have a 3" lift and have run 32mm spacers for 3 years without issue. I think more strain is put on by oversize tyres and in particular muds. if lifted, spacers will balance things out and will feel more stable. make sure the offset of the wheel does not make the tyres protrude too much.
12 years 3 weeks ago #127610
by Rhinoman
Replied by Rhinoman on topic wheel spacers...
Bearings don't usually fail catastrophically, you will get play in them which will be noticeable long before they break. 32mm is the most common size because that is what is available, 25mm used to be common because that was the limit for spacers in the AWDC regulations, I don't know if that has changed.
Time to create page: 0.089 seconds
