2" body lift installation.
  • darthloachie
24 Oct 2014 11:26 #127369 by darthloachie
Replied by darthloachie on topic Re:2" body lift installation.
just cut the metal arches back now you've got the extended arches fitted
  • Flameboi201
24 Oct 2014 13:27 #127384 by Flameboi201
Replied by Flameboi201 on topic Re:2" body lift installation.
jimnydms wrote:
Flameboi201 wrote: Biger bump stops mite help .
yeah never thought about that, maybe body lift isnt the way to go then, you're intending on fitting 33's arnt you so you would have the same prob if not worse of the tyre fouling on that part of the body
Yes or 35s but will have yota axles that are slightly wider and i will just crank plasma up until no more rubbing lol
  • TomDK
24 Oct 2014 13:57 #127388 by TomDK
Replied by TomDK on topic Re:2" body lift installation.
bumpstops are only meant to stop the shocks from bottoming out. correctly set up they don't limit suspension travel or articulation.
  • Nicks_Jim
24 Oct 2014 17:52 #127411 by Nicks_Jim
Replied by Nicks_Jim on topic Re:2" body lift installation.
jimnydms wrote:
TomDK wrote: Why a 2" bodylift when you already have a 4" suspension lift?
Should have room enough for the 31" tyres.
Here is a pic of where it is rubbing, this is basically looking at the back of the front bumper
Hi jimnydms, this is what I had to do to mine with 33inch tyres . Nick
  • jimnydms
24 Oct 2014 23:12 #127445 by jimnydms
Replied by jimnydms on topic Re:2" body lift installation.
You cut the box section back behind the head lights what lift did you have etc?
  • jimnydms
24 Oct 2014 23:15 #127447 by jimnydms
Surely if you modify to a longer
Bump stop it will impinge the articulation to where you have put the bump stop to ? The axle will stop at the bump stop inside the spring and stopping it articulating as much and not compressing the shock as much as well as the spring as that is where the bump stop is located ?
Time to create page: 0.663 seconds
