2" body lift installation.
  • jimnydms
21 Oct 2014 08:51 #127061 by jimnydms
2" body lift installation. was created by jimnydms
Does anyone know if it is possible to install a 2" body lift without taking bumpers off I have HD ora front and rear bumpers. Rear is not an issue really but the front is a pain n my own as the winch is only just fitted in there and it's a pain to take it all off again ?
Any advice appreciated.
Thanks
21 Oct 2014 11:42 #127075 by Basketcase
I know the front body mount bolts are under the front headlights
  • Flameboi201
21 Oct 2014 12:05 #127077 by Flameboi201
Replied by Flameboi201 on topic 2" body lift installation.
Your bumper is bolted to chassis and you are lifting the body so you will have to lift the bumpers to match new body position or you will have a 2 inch gap
  • jimnydms
21 Oct 2014 13:13 #127081 by jimnydms
Replied by jimnydms on topic Re:2" body lift installation.
I have spoke to ora and they can make me some brackets for the bumpers to raise those also which means I suppose I ll have to take them off any way :-/
  • TomDK
21 Oct 2014 15:08 - 21 Oct 2014 15:10 #127097 by TomDK
Replied by TomDK on topic Re:2" body lift installation.
Why a 2" bodylift when you already have a 4" suspension lift?
Should have room enough for the 31" tyres.
Last edit: 21 Oct 2014 15:10 by TomDK.
  • jimnydms
21 Oct 2014 18:25 #127122 by jimnydms
Nope they are catching at the front of the front arch on the chassis by the front body mount. I ll take a pic. I have 0 offset and 32mm spacers which helps but not on full lock on full articulation. Hence a 2" body lift on the cards. My wheelseasurw up at 32" also
Time to create page: 0.379 seconds
