Clutch Cable
  • pcrepairmandan
12 years 4 weeks ago #126998 by pcrepairmandan
Clutch Cable was created by pcrepairmandan
is the clutch cable easy to clean? my clutch has become SOLID to press down
12 years 4 weeks ago #127000 by j999pre
Replied by j999pre on topic Clutch Cable
I have a good second hand one
Grey pick up Jimny
12 years 4 weeks ago #127001 by mlines
Replied by mlines on topic Re:Clutch Cable
I would have thought it was more likely to be the cluch thrust bearing not sliding on the shaft. Has it been off roaded? If its the cable then a new one is best as the issue is the nylon liner wears through on the curve of the cable and used ones will be starting to wear.
Sent from my Nexus 5 using Tapatalk
  • BensJimny
12 years 4 weeks ago #127003 by BensJimny
Replied by BensJimny on topic Clutch Cable
Had the same problem, i thought it was the pedal return spring at first but a drop of lithium oil down the cable casing and allowing it to soak in and run through got it moving like new again, trying a drop of oil has to be slightly cheaper than buying a new part, could try it at least! plus its a 10 minute job tops loosen the cable, un clip, pull through the bulkhead and clean and oil. Can get grotty very easily so a clean is recommended! Good Luck!
  • S Mark
12 years 4 weeks ago #127010 by S Mark
Replied by S Mark on topic Clutch Cable
BensJimny wrote: Had the same problem, i thought it was the pedal return spring at first but a drop of lithium oil down the cable casing and allowing it to soak in and run through got it moving like new again, trying a drop of oil has to be slightly cheaper than buying a new part, could try it at least! plus its a 10 minute job tops loosen the cable, un clip, pull through the bulkhead and clean and oil. Can get grotty very easily so a clean is recommended! Good Luck!
+1 I have oiled mine a couple of times I take mine off remove the rubber gators and drip some automatic transmission fluid ATF in mine till it comes out the other end, takes a bit of time but well worth it.
  • pcrepairmandan
12 years 4 weeks ago #127062 by pcrepairmandan
Replied by pcrepairmandan on topic Clutch Cable
I was at Frickley on Sunday with a couple of lads and one of them said his got so hard to push after it had been off road
and he took it off cleaned it all out ( the cable )
is it actually a ten minute job to do haha? need to get it up and running ready for KORC on sunday :D
Time to create page: 0.090 seconds
