Jimny lamda sensor
  • Dave!
19 Oct 2014 17:03 #126909 by Dave!
Jimny lamda sensor was created by Dave!
Hey guys,
when i first purchased my jimny the cat had blocked, so i purchased and fitted a new cat and then replaced the spark plugs. since then i have been sat with the car on tick over and it tends to drop intermittently below 1k revs
i have also read that there is the possibility that the lambda sensor has gone as my car is on the recommended mileage for a new one.
Going up hill my car also struggles and has been known to stall up strong inclines.
i have a new lambda sensor downstairs ready to be fitted, does anyone know how to do this or maybe a tutorial?
kind regards,
Dave.
19 Oct 2014 17:48 #126913 by j999pre
Replied by j999pre on topic Jimny lamda sensor
I bad lambda normally throws the engine manager light on.
You have one in your exhaust manifold 22mm ring spanner
Grey pick up Jimny
22 Oct 2014 12:10 #127173 by Rhinoman
Replied by Rhinoman on topic Jimny lamda sensor
A bad lambda won't always throw the engine management light, it can be bad enough to cause running issues but not dead enough to trigger a fault.
In this case I would first check for exhaust leaks prior to the cat. Didi you check the spark plug gaps were correct?
  • Dave!
27 Oct 2014 01:48 #127596 by Dave!
Replied by Dave! on topic Jimny lamda sensor
I have had the cat replaced already, i believe that the spark plugs are set up correctly.
27 Oct 2014 12:56 #127609 by Rhinoman
Replacing the lambda sensor should be a fairly straightforward process. Unplug it, unscrew it and then screw the new one in and plug it in. I recommend using the special sockets that they sell for the lambda sensor, the chances are the old one will be seized so you will need to get some leverage on it. The new one should be fitted with some high temperature anti-seize compound around the thread, some sensor will come with this, the cheaper ones won't.
Its worth replacing the sensor as a precaution, its possible that, with a blocked cat, the sensor has been overheated.
27 Oct 2014 15:47 #127624 by facade
Replied by facade on topic Jimny lamda sensor
Rhinoman wrote: Replacing the lambda sensor should be a fairly straightforward process. Unplug it, unscrew it and then screw the new one in and plug it in. I recommend using the special sockets that they sell for the lambda sensor, the chances are the old one will be seized so you will need to get some leverage on it.
I changed the one on the RAV4. Took all afternoon as I had to take the manifold extension off to get a decent spanner to it. (and then I sheared off one of the studs.......... :evil: )
Those comedy split sockets (that thread over the wire) simply open up and go round before you get anywhere near normal LandRover leverage :ohmy: I did try the dodge of putting a worm drive clip round it and tightening that up with no joy.
It took a proper 22mm deep ring spanner and a lot of force to undo it, and then it left all the thread in the hole.
How I laughed at all the extra work :dry:
Hopefully, yours wont be that tight.....
Time to create page: 0.104 seconds
