Jimny lamda sensor
- Dave!
12 years 4 weeks ago #126909
by Dave!
Jimny lamda sensor was created by Dave!
Hey guys,
when i first purchased my jimny the cat had blocked, so i purchased and fitted a new cat and then replaced the spark plugs. since then i have been sat with the car on tick over and it tends to drop intermittently below 1k revs
i have also read that there is the possibility that the lambda sensor has gone as my car is on the recommended mileage for a new one.
Going up hill my car also struggles and has been known to stall up strong inclines.
i have a new lambda sensor downstairs ready to be fitted, does anyone know how to do this or maybe a tutorial?
kind regards,
Dave.
kind regards,
Dave.
12 years 4 weeks ago #126913
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Jimny lamda sensor
I bad lambda normally throws the engine manager light on.
You have one in your exhaust manifold 22mm ring spanner
Grey pick up Jimny
12 years 3 weeks ago #127173
by Rhinoman
Replied by Rhinoman on topic Jimny lamda sensor
A bad lambda won't always throw the engine management light, it can be bad enough to cause running issues but not dead enough to trigger a fault.
In this case I would first check for exhaust leaks prior to the cat. Didi you check the spark plug gaps were correct?
- Dave!
12 years 3 weeks ago #127596
by Dave!
Replied by Dave! on topic Jimny lamda sensor
I have had the cat replaced already, i believe that the spark plugs are set up correctly.
12 years 3 weeks ago #127609
by Rhinoman
Replacing the lambda sensor should be a fairly straightforward process. Unplug it, unscrew it and then screw the new one in and plug it in. I recommend using the special sockets that they sell for the lambda sensor, the chances are the old one will be seized so you will need to get some leverage on it. The new one should be fitted with some high temperature anti-seize compound around the thread, some sensor will come with this, the cheaper ones won't.
Its worth replacing the sensor as a precaution, its possible that, with a blocked cat, the sensor has been overheated.
12 years 3 weeks ago #127624
by facade
I changed the one on the RAV4. Took all afternoon as I had to take the manifold extension off to get a decent spanner to it. (and then I sheared off one of the studs.......... :evil: )
Those comedy split sockets (that thread over the wire) simply open up and go round before you get anywhere near normal LandRover leverage :ohmy: I did try the dodge of putting a worm drive clip round it and tightening that up with no joy.
It took a proper 22mm deep ring spanner and a lot of force to undo it, and then it left all the thread in the hole.
How I laughed at all the extra work :dry:
Hopefully, yours wont be that tight.....
Replied by facade on topic Jimny lamda sensor
Rhinoman wrote: Replacing the lambda sensor should be a fairly straightforward process. Unplug it, unscrew it and then screw the new one in and plug it in. I recommend using the special sockets that they sell for the lambda sensor, the chances are the old one will be seized so you will need to get some leverage on it.
