new jimny - 1st mods help
  • davert85
18 Oct 2014 08:47 #126815 by davert85
new jimny - 1st mods help was created by davert85
Before I go mad with the mods and I want to make sure the basics are covered first ie better recovery mounts (stronger) and other little touches which will toughen up the little him for when the big mods and off roading come along. Being new to this can anyone give me a few pointers on what I need to do,things to buy and where from. Il be cutting down the bumper later today/tomo and have ordered some recovery straps.
Any tips and advice welcome.
Thanks.
David.
  • davert85
18 Oct 2014 10:34 #126826 by davert85
Replied by davert85 on topic new jimny - 1st mods help
Recommendations on breather kits and so on to would be handy
Thanks all
18 Oct 2014 11:18 #126827 by robs5230
Replied by robs5230 on topic new jimny - 1st mods help
mine has diff and box breather tubes all made from reinforced garden hose. all terminating high up on the bulkhead under the bonnet with a foam plug in the end to keep the muck out. you need to keep an eye on them around the diffs as they can damage easily. leave plenty of slack and they are easy to trim off and refit to the diff
standard jimny - for now
The following user(s) said Thank You: davert85
  • Vinnie
18 Oct 2014 11:29 #126829 by Vinnie
Replied by Vinnie on topic new jimny - 1st mods help
robs5230 wrote: mine has diff and box breather tubes all made from reinforced garden hose. all terminating high up on the bulkhead under the bonnet with a foam plug in the end to keep the muck out. you need to keep an eye on them around the diffs as they can damage easily. leave plenty of slack and they are easy to trim off and refit to the diff
Why are breathers not fitted ?
  • Grego
18 Oct 2014 12:42 #126834 by Grego
Replied by Grego on topic new jimny - 1st mods help
I know why you need an engine breather , but a breather in a gearbox or axle casing..? Why are they needed?
18 Oct 2014 13:08 #126836 by robs5230
if you don't fit extended breathers to diffs and boxes and go through deep water, the water will enter the diffs and boxes and turn the oil into mayonnaise
Time to create page: 0.090 seconds
