Pulling left under braking
  • The Dug
12 years 1 month ago - 12 years 1 month ago #126657 by The Dug
Pulling left under braking was created by The Dug
Just replaced the nearside king bin bearings, both disc & pads (didn't overhaul the calipers but they were both moving OK as I did them relatively recently) also replaced rear shoes then bled the all round.
Taken it out for a wee test run and find it pulling to the left under heavy braking - at a bit of a loss what to try next so any advice or experience gratefully accepted.
Was thinking maybe wheel alignment but that's clutching at straws.
Cheers folks.
Last edit: 12 years 1 month ago by The Dug.
12 years 1 month ago #126658 by Rhinoman
Replied by Rhinoman on topic Pulling left under braking
If its pulling to the left then the problem is more likely to be the offside brake is not working properly.
  • The Dug
12 years 1 month ago #126661 by The Dug
Replied by The Dug on topic Pulling left under braking
Thanks for the reply, that's exactly what I thought too so I took the drivers side caliper off checked everything - sliders sliding and piston.... pisting???
12 years 1 month ago #126775 by Rhinoman
Check that the rears have adjusted up properly.
  • The Dug
12 years 4 weeks ago #127028 by The Dug
You could be right, the 'C clip' on the NSR shoes popped yesterday so I replaced it and reset the brakes.
Not pulling any more.
Thanks for the replies mate.
  • xtremedetailz
12 years 4 weeks ago #127032 by xtremedetailz
Replied by xtremedetailz on topic Pulling left under braking
I know its a daft one but are tyre pressures the same ?
