HELP! 26 spline shaft conversion / spacer
- Jimny-Dave
12 years 1 month ago - 12 years 1 month ago #126286
by Jimny-Dave
HELP! 26 spline shaft conversion / spacer was created by Jimny-Dave
Hi! Need some help!
Currently have my Jimny front axle stripped in the garage, and have come across a little problem...
Remember, I come from Vitara-land, so please be gentle with your responses
it might be an obvious question to some, but I'm new to all this!
Ok, I've followed Martin's very helpful quide to changing the kingpins/bearings to strip down to this level -
So that the shaft and CV is out, and the hub is off, ready for me to fit (in conjunction with the front LSD) 26 spline RS-Mfg shafts and big CVs, ok, I'm alright with doing all that... but, the kit includes a spacer -
Which obviously comes with some longer bolts to fit it... BUT... now, here's the problem... I have this ABS ring (looks like a bike sprocket!) in the way -
So... do I have to undo the bearing retaining nut with a bearing tool to be able to strip what's around the hub to be able to get the longer bolts in?...
I'm presuming on a non-ABS model this bit is simple, but I have the ABS ring in the way?...
Last edit: 12 years 1 month ago by Jimny-Dave.
- Jimny-Dave
12 years 1 month ago - 12 years 1 month ago #126293
by Jimny-Dave
Replied by Jimny-Dave on topic HELP! 26 spline shaft conversion / spacer
- TomDK
12 years 1 month ago #126298
by TomDK
Replied by TomDK on topic HELP! 26 spline shaft conversion / spacer
Great pics Dave.
Have you gotten it all installed by now?
If not can you take a few pics of the new uprated shafts and CVs next to the standard ones. Just for comparison
- Jimny-Dave
12 years 1 month ago #126312
by Jimny-Dave
Thanks Tom!
Installed... err, no... not quite! (See below)
But, yes, I will take some comparison photos before I proceed...
- Jimny-Dave
12 years 1 month ago #126314
by Jimny-Dave
It's never easy is it!
The LSD equipped diff wouldn't fit it...
So, after a text conversation with Rockwatt (thanks for answering on a Sunday evening Richard!
) I decided to make it fit...
I noted what was catching where -
And then... yes, you guessed it... Mr. Angry was called in...
Diff fits! :laugh:
Just having Sunday roast and then back out to thoroughly clean the inside of the axle casing before start to re-assemble...
Diff fits! :laugh:
- TomDK
12 years 1 month ago #126316
by TomDK
That LSD diff looks interesting? What is it from?
Is it same ratio as the standard Jimny rear diff, with the bigger ring gear?
Can see why it takes some time to get done
And yes, Richard is a very helpful bloke
Time to create page: 0.092 seconds
