Jimny fault code p0135
- shoestring
09 Oct 2014 20:25 #126093
by shoestring
Jimny fault code p0135 was created by shoestring
Hi all I'm new to the site I've just bought myself a 2001 jimny and the engine management light is on I deleted it and removed any codes after using it for a day or so the light has come back on when checked the code has come up as P0135 heated oxygen censor can anyone tell me where this is on my vehicle (1.3) engine I think it is the lambda sensor but confused there is two one in the manifold and one behind the cat if anyone can help I would be grateful thanks. Richie.?
09 Oct 2014 20:33 #126094
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Jimny fault code p0135
That is the manifold lambda sensor. Very common
Grey pick up Jimny
The following user(s) said Thank You: shoestring
- shoestring
09 Oct 2014 21:13 #126098
by shoestring
Replied by shoestring on topic Jimny fault code p0135
Thanks for the info going to try it I'll keep you updated .
Richie
Richie
- shoestring
04 Nov 2014 16:45 #128475
by shoestring
Hi thanks sorry it's a bit late but you were spot on with the lambda sensor in the manifold all that left for me now is the 3 weeks welding on the body looking forward to it .
Richie
Richie
Time to create page: 0.082 seconds
