Fitting new exhaust
  • Carrow
12 years 1 month ago - 12 years 1 month ago #125947 by Carrow
Fitting new exhaust was created by Carrow
Hi,
Can anyone help, I have a 2008 Jimny with M13AA engine, I want to fit a KAP Suzuki rear Silencer which is based on the pre 2005 (G13BB engine) with the flange on the side of the box. There are subtle differences between the middle pipe and rear box on my 2008 jimny and the pre 2005 exhaust mid pipe and back box.
The middle pipe on my 2008 has no bend where it enters the back box, from what I can see the bend was moved to the back box itself. I have been told all I need to do is use the pre 2005 centre pipe which has the bend. Is this correct?
heres an image similar to my centre pipe and back box. note the bend is on the back box, and not the centre pipe.
Last edit: 12 years 1 month ago by Carrow. Reason: added an image.
12 years 1 month ago #125953 by mlines
Replied by mlines on topic Fitting new exhaust
I hope my emailed replies help
The following user(s) said Thank You: Carrow
  • Carrow
12 years 1 month ago #125960 by Carrow
Replied by Carrow on topic Fitting new exhaust
Thanks, yes it did, seems as long as you change both rear box and middle pipe from same year pre 2005 they will fit the newer models.
Thanks again.
Time to create page: 0.079 seconds
