Remove cat.
  • steffan
12 years 1 month ago #126229 by steffan
Replied by steffan on topic Remove cat.
Is there a way the sensors can be deleted like the dpf sensors are
12 years 1 month ago #126248 by kirkynut
Replied by kirkynut on topic Remove cat.
RichiesJimny wrote:
kirkynut wrote: I shall try to answer all your questions at once.
A Jimny with no cat or an ineffective worn out cat ought to pass an mot on emissions as long as the cat is not blocked and there's no other issue with the car like worn piston rings causing high emissions.
They are tested on the pre 1992 emissions figures because Suzuki didn't release emissions figures for the earlier Jimnys. This may be and is likely to be different for later cars, from when I don't know. Mine is a 2000 model.
Can an mot tester on here look jimny emissions up for us please.
The only thing is that although the emissions may be good enough for the relevant test the car knows that the emissions are not as good as they could be with a working cat so it pops on an engine management light with a code for bad cat efficiency. That light is an mot failure.
There has to visibly be a cat present for the mot and the light must not be on. The light has to come on and go out when the car starts too or you get an advisory which may be a fail if not fixed for next year. Ie: you can't just remove the bulb.
How hard can it be to make an led light for 5 seconds when fed an ignition only live though? I mean on it's own independent circuit to look like it's right. Maplins!
When my cat failed but did not get blocked I kept putting the light out for over a year before an un knowledgeable mot tester failed it on emissions. I went elsewhere for my mot the next year and my friend was the tester who told me that there was little chance of it passing the post 1992 test even with the new cat so he wouldn't bother but showed me as I expressed curiosity.
He told me that there were no figures for the Jimny so as long as it passed the pre 1992 emissions test it was fine.
It ran ok when the light was on. It was simply telling me that the emissions were high for a car that has a cat. If I had made sure that the light was out and taken it to him the previous year it would have passed and I wouldn't have paid for a new cat and would just keep putting the light out once a month.
Disclaimer: This is knowledge I have picked up along the way which I believe to be true. I am not an mot man and have not studied the rules.
I'm not sure where your tester gets his info from but if you follow the flow charts it clearly states if you cannot find an exact match in the emission data base carry out the emission test to default limits.
So all jimny's must pass an emission test. :)
The engine management light is not part of the test and any advisory items are purely advisory it doesn't mean you must fix them.
All the test manuals are on line now but you must read them very carefully
www.motinfo.gov.uk/htdocs/m4s07000309.htm
www.motinfo.gov.uk/htdocs/m4s07000311.htm
To be fair that's probably what he said about the emissions. It was about 3-4 years ago! Hence my disclaimer as it was as best as I could remember.
So what's the default cat limits?
Isn't there a new thing about advisories having to be fixed in future tests or is that just talk? I don't see how it could work.
12 years 1 month ago - 12 years 1 month ago #126251 by Rhinoman
Replied by Rhinoman on topic Remove cat.
The limits are in that first link. Technically its possible to delete the second lambda sensor but it would still have to pass that test. Deleting the first lambda sensor makes no sense because the ECU would lose its ability to self tune.
Advisories are held on the computer system.
Last edit: 12 years 1 month ago by Rhinoman.
Time to create page: 0.089 seconds
