Switch illumination
- Huskynose
12 years 1 month ago #125755
by Huskynose
Switch illumination was created by Huskynose
Hi Peeps,
just wondering whether the dashboard switches for the rear window heat, rear wiper, rear fog and such are supposed to be illuminated.
In my Girl's Jimny they appear to be dark.
Also the reversing lights don't work.
Are these two items related ?
I do have illumination on the dials and the heater controls.
12 years 1 month ago #125756
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Switch illumination
Switches no.
Reverse light is one bulb suo check that first. If your not getting power it could be the switch on the gearbox
Grey pick up Jimny
12 years 1 month ago - 12 years 1 month ago #125920
by kirkynut
Replied by kirkynut on topic Switch illumination
I have 2 reverse lights but still worth checking the bulbs to eliminate them as the problem.
I have had to change the switch on the gearbox as mine went. Not a tricky job once you've found it on top of the gearbox. Just use an adjustable spanner as you can't see what you're doing well and can't see what size it is and I can't remember!
I might have posted the size on here for situations like this if you search my posts and reversing switch.
It's annoying the rear screen heater switch is not lit but it's not.
Last edit: 12 years 1 month ago by kirkynut.
Time to create page: 0.079 seconds
