Spring Removal without clamps??
  • Statey
04 Oct 2014 14:56 #125708 by Statey
Spring Removal without clamps?? was created by Statey
I've done Google searches & Searches on here and can only find vitara instructions.
I've got some spring spacers went out this morning jacked up the body, put on Axel stand then jacked up and removed the shock, but then when I dropped Axel off the shock it wouldn't go low enough to remove the spring. Am I missing something or is it not possible without spring compressors? (Passenger side)
Cheers
  • supergaz
04 Oct 2014 15:00 #125709 by supergaz
Replied by supergaz on topic Spring Removal without clamps??
Brake hose is stopping the axle from dropping also the anti roll bar if still on.
Axle stands under chassis, then jack under diff, wheels off then lower axle down.
  • Statey
04 Oct 2014 15:09 #125710 by Statey
Replied by Statey on topic Spring Removal without clamps??
ARB's long gone, there didn't seem to be a lot of tension on the hose when it dropped but I'll have a look :)
04 Oct 2014 15:14 #125711 by robs5230
like gaz says.
standard jimny - for now
  • Vinnie
04 Oct 2014 16:22 #125716 by Vinnie
Replied by Vinnie on topic Spring Removal without clamps??
I put a 2.5 lift on mine with arb still attached :cheer:
  • X8GGY
04 Oct 2014 16:50 - 04 Oct 2014 16:51 #125719 by X8GGY
Replied by X8GGY on topic Spring Removal without clamps??
My best tip... when you remove the shock bolt and lower the jack, take it round the other side and jack under the other end of the axle... one side goes up, the other has to drop down ;)
Then get spouse / girlfriend / parent to stick their foot and weight on top of the brake to push it down a little too...
And unclip the brakeline should get you a bit more droop too...
Dave ;)
Last edit: 04 Oct 2014 16:51 by X8GGY.
Time to create page: 0.103 seconds
