2" lift kit
- Whaley
03 Oct 2014 07:39 #125626
by Whaley
2" lift kit was created by Whaley
Hello everyone im looking into fitting a 2" lift kit do i need to fit adjustable panhard arms ? Or are they only needed for bigger lift's i dont want it to get to expensive ! Im looking at the kit and the rear shock repostioners at the moment.
03 Oct 2014 20:26 #125672
by robs5230
standard jimny - for now
Replied by robs5230 on topic 2" lift kit
the panhard is fixed axle to chassis. if you lift the jimny the angle of the panhard will steepen but as the rod is a fixed length the axle has no choice but to pull over. the amount the axle moves may not be much but it aint right so yes i'd get adjustable panhard rods.
The following user(s) said Thank You: Whaley
Time to create page: 0.073 seconds
