engine check light on
12 years 1 month ago #125069
by safari
if u worry u die if u dont worry u still die so why worry
engine check light on was created by safari
hi as title says i have a jimny wide 1998 and have the engine check light on. what can it be just changed the oil and filter
tks for the help
tks for the help
12 years 1 month ago #125075
by Rhinoman
Replied by Rhinoman on topic engine check light on
It could be almost anything, you need to read the fault codes from the ECU. This can be done using a wire jumper in the monitor coupler. details here:
www.rhinopower.org/diag/cel.html
12 years 1 month ago #125079
by safari
tks will try it out
Replied by safari on topic engine check light on
Rhinoman wrote: It could be almost anything, you need to read the fault codes from the ECU. This can be done using a wire jumper in the monitor coupler. details here:
tks will try it out
Time to create page: 0.077 seconds
