Help Required Fitting a 2" Lift Kit
- Dyl
I recently bought my Jimny and want to prepare it for some green laning and raising it is part of that. Unfortunately I can only use my right arm and although that doesn't stop me doing most things but I think a job like this just may prove too tricky for me to tackle safely one handed.
I could buy the parts and find a local garage but I would prefer a Jimny enthusiast working on it if possible.
I was looking at buying from Jimnybits a 2" lift kit, extended brake hoses, camber correction bushes and rear shock repositioners. Im thinking this is what I need to carry out a lift but please tell me if I'm wrong.
I also want to add a transfer box guard but I'm sure I can fit that ok
Anyway, I thought I would ask and as I said I am willing to pay and travel.
Thanks
- Vinnie
Dyl wrote: Im looking to see if anyone can help me fit a 2" lift kit and the bits needed to go with it. I am happy to pay for this, I am not here looking for a free favour.
Thanks
Hi I'm quite new to jimnys but asking around and reading posts etc with a 2" lift you can get away with standard brake lines and don't need castor correction bushes,you can get away with out shock repositioners but the bushes will wear quicker so its a good mod.
You need to start adding these extra parts if you go 2.5 like I've just fitted or over
I'm sure one of the more experienced will add to this.
Sorry cant help with fitting though not local to you.
Cheers vinnie.
- Dyl
I was going to add the extended brake hoses after reading that if you decide to remove the anti roll bar, which it seems most people advise, then the longer hoses are required, but I could be wrongVinnie wrote: Hi I'm quite new to jimnys but asking around and reading posts etc with a 2" lift you can get away with standard brake lines and don't need castor correction bushes,you can get away with out shock repositioners but the bushes will wear quicker so its a good mod.
Cheers vinnie.
The correction bushes and shock repositions I took the recommendation from Jimnybits site. To be honest, if Im going to lift it, I may as well do it in one hit.
